Scenic Reversing lights fuse
8.5K views 3 replies 3 participants last post by  madnoel10
#1 ·
My 1st post on this forum..so here goes.
Both reversing lights on my 2000 Scenic have stopped working. I dont think it's the bulbs as I cant see both going at the same time. So it's gotta be either a fuse or the reverse light switch on the gearbox.
Before I fork out for a new switch can anyone please tell me what fuse I'm looking for & where it would be located? After a bit of searching it seems the Scenic has two fuse boxes, but I cant find the one under the bonnet or the owners manual.
Any help is appreciated:)
#2 ·
the fuse box in the cab should be on the right side low down on the dashboard, sort of below knee level. It is a small pull down flap, all the fuses and what they do are listed on the inside of the flap. Your handbook should explain all.
I would go out to the car and check which fuse it is etc, but for 2 reasons. 1. It's damn cold today and 2. I'm off work with flu!
Hope that was helpful.:cool:
