401 - 418 of 418 Posts
Hi Do you definately have to remove the whole rear access as there is a description on the site saying no you do them individually .
Using the proper tool the rear bushes can be replaced with the rear axle in situ., My local independent usually charges 2-3 hours labour with £50 for genuine Renault bushes which seem to last much longer than the after-market units:)
how do you check these bushes
i think that my bushes are failing as i get a creaking from the rear end of the car also when i go over a bump i get a thud
so can someone please tell me how to check these bushes
Bushes Laguna MkII
Had these replaced twice I think sine 2003. Due for another one. Ramps on roads don't help apparently? Anyway, about £200 at a dealer or by a top Polish mechanic? Door seal on near side went and shorted satnav - ignition systems via carpet and electical junction box found like old Lagunas in footwell on near-side panel. Under warranty - this was fixed. When car was delivered with 10 000 on the clock from London depot in-built satnav knicked! Renault had to relpace at their cost. VERY expensive. This will be my next info.:crazy:
Laguna rear bush replacement
Thought I would share my experiences with forum members. I decide to buy the press tool from E-Bay - looked brand new and cost £70 - and also decided on genuine Renault bushes (£51 per pair) rather than save a few quid on cheaper ones and risk them not lasting very long. My original ones lasted 98,000 miles. I used 4 axle stands for safety (you could get away with 2) a 2 ton trolley jack, the press tool, 24mm and 16mm 1/2" drive sockets and ratchet, 24mm ring spanner, wire brush, copper grease, penetrating oil and a few blocks of wood. On a hard level surface, jack up each side of the car at the rear, using the cars sill jack so the rear wheels hang free - ie. no load on the rear springs. Lift the car as high as you can and put an axle stand just forward of the jacking point behind the lip of the sill on the rail which runs lengthways behind the sill - make sure the axle stand bears on a load bearing part of the chassis - thin pieces of ply wood on top prevent the metal of the stand digging into the underseal. Chock the front wheels. Remove both rear wheels. Place trolley jack, with a block of wood, under the centre of the beam axle to support its weight. Unclip the hand brake cables and ABS wires from each side of the axle beam. With a 16mm socket, undo the long bolts which go through the centre of both bushes and also locates the stabiliser bar which holds the brake pipes bracket and take them out. Make sure you do not allow the brake pipes to stretch or kink as the stabiliser bar is now loose. Next, with the same socket, undo the three bolts each side which hold the retaining brackets over the bushes. The inside bolts were very tight as they are the only ones exposed to road dirt and the threads were very rusty. The other bolts were completely clean and came out easily. Remove both brackets (don't mix them up as they are right and left hand) and clean off road dirt from brackets and bolts with a wire brush. The bushes are now exposed. I carefully lowered the trolley jack, expecting the axle to move but it did not as it is suspended on the shock absorbers at full entension and the bushes were still pressed hard against the chassis by the weight of the axle. I placed the trolley jack under the thick part of the near side brake disc, with a wooden block and lifted the axle beam. The axle pivots on the shock absorber and as the back of the axle lifts, the front of the axle containing the bush moves down making room to get the tool in over the old bush. You will need to manouevre the axle by pulling it to get it into a position where you can insert the long bolt into the centre of the puller. All the time, keep checking that you are not putting strain on the brake pipes, ABS wires and headlamp levelling mechanism. Make sure the puller is square over the old bush and wind it out with a 24mm socket beneath and a 24mm ring spanner above. Once the old bush is out, clean up the hole with a wire brush and lubricate the hole with copper grease. Place the new bush over the hole, reverse the puller and pull the new bush into position, again making sure everything is square. Repeat the process on the off side, jacking up the offside of the axle, on the thick part of the brake, disc to gain access to the bush. Refit the two brackets using the three bolts each side but, at this stage, don't do up the bolts for the last 3/4" of thread. The brackets need to be located on the bolts but loose. You then need to manouevre the axle, one side at a time so you can get the long centre bolt through the centre of the bush. Again you need to jack the rear of the axle beam to take the strain off the new bush which, when the axle is hanging free, will be pressed hard up against the chassis. Lifting the axle also brings the new bush square with it's hole making refitting of the bolt much easier and reducing the chance of cross threading it. Don't forget that this bolt also holds the stabiliser bar so don't forget to refit it. Fasten the centre bolt up tight and repeat on the other side. Finally fully tighten the three bolts per side which hold the brackets. Refit the handbrake cables and ABS wires into their brackets, refit the road wheels and lower the car to the ground. Get yourself a well deserved beer or cuppa! The near side is the most difficult because of the location of the brake pipes and headlamp levelling mechanism and took about an hour and a half. The off side is dead easy and took about twenty minutes. Total cost of job £121 and I will sell the tool back on E-Bay and make some money back. With the tool, the job is easily within the ability of a DIY mechanic. Wouldn't like to do it without it though. The car is completely transformed now with no knocking from the back axle and it handles much better.
Hi guys just had my rear bushes done at dealers????....£286 fitted and vat.couldn't be bothered with the hassel of doing them myself.no bumps at the back end now....:eek:
Same with me excavator, about the same price, BUT they then showed me one of the springs had broken, just the last 4" of one of them.
Waited another hour and they got me 2 new ones and fitted them at a greatly reduced price as they already had the axle stripped out.
So not too bad.
Save
it's sure made a difference to the motta and an even bigger difference to the bank balance,i just couldn't be bothered to do it myself.had the cam belts done at same time that was a big one parts and labour £500!!!!!but i was over the time change by 2years so i was on borrowed time???
Re: Laguna 2 Rear Axle Bushes-Read This!
just done this job on my car so thought id write down the instructions
Laguna rear axle bush change instructions
(1) Jack up rear of vehicle on both sides, and put stands under both sides of the body so as the wheels are of the ground.
(2) Remove both rear wheels, put the jack under the axle as a support, and unclip the brake pipe flex hoses from the support bar and the abs and handbrake cables.
(3) Undo both bush carrier centre bolts, and then remove the link bar that the brake pipes were attached to,(some cars may have a level sensor attached to this bar for the headlamps, this must be disconnected as well).
(4) Undo both bush carriers from the body (don’t worry it wont drop due to the shocks being still connected, you can now see the bushes.
(5) Put the jack under one side under where the spring sits and take the weight of the axle, then remove the shock top bolt this is much easier than the bottom, then lower the jack. You should now have good access to fit the wind out tool.
(6) Spray the old bush with wd40 and wind it out, don’t worry they aren’t that tight, once out clean the hole and refit the new bush with the tool (remember the bushes are not the same on both sides). Jack back up and fit top shock bolt.
(7) Repeat items 5 and 6 for the other side.
(8) Reattach the bush carriers to both sides using the centre bolt only first .don’t forget the bolt has to go through the brake pipe support bar, You may have to jack the axle up to align the bolts with their holes. Once they are in fit the remaining bolts and tighten them all.
(9) Reclip the brake pipes, abs wires and handbrake cables in place.
(10) Take 5 mins to double check the tightness of everything then refit your wheels, remove from stands and enjoy no more banging from the rear.
(11) This is not a hard job to do and took me 2.5 hours from start to finish not knowing what i was doing.
(12) You can do it
Hi want to make arear axle bush removal tool ,can someone who has the tool please give dimentions please
for the true amateur mechanic would recomend
1. buy a removing tool from ebay(inc pattern bushes £88)
2. only use genuine renault bushes £60 inc vat
DO NOT USE PATTERN BUSHES THEY DO NOT FIT AND WILL NEVER FIT
THE GENUINE BUSHES HAVE A LARGE TAPER TO LOCATE IN AXLE YOU NEED THIS
TO LOCATE AND FIT THE BUSHES
3. you can remove and replace one bush at a time
4. give yourself plenty of time the real problem is locating the bush bolt threw bearing and subsequently antiroll bar and cover plate
good luck to you all took myself and my dad 2 full days and a lot of swearing to realise pattern parts will not fit
You have insufficient privileges to reply here.
